Session two was the first timed session and i thought i better go out and have a crack before the weather came in... I warmed the tyres and started to push the pace a bit more... Once again i had understeer and trouble under brakes, i was getting a little annoyed as i was expecting the car to be a massive improvement with new front tyres and alignment and instead i was fighting the car to turn...
At this stage i knew something was wrong... Being a noob to Semi's i asked John Boston if i needed to do anything with fresh "green" tyres and was told they should be fastest right out of the box, so i checked the pressures again and this is where i started to find my first drama... The front left hot was 26psi, front right 29psi and the two rear were 32psi... Weird but i figured i had stuffed up the first time so chucked some air in the front and kept going...
The brakes were an issue as mentioned above, SMSP South was to blame for this as the last session was an open session and as i was having so much fun i decided to go lap after lap mucking around without a cool down between... When returning to the pits i actually though the front of the car was on fire with the smoke coming from the brakes lol... This was all good and well and forgotten by the time it was track day again, however it was soon remembered when i went flat out to the normal braking marker and completely missed the apex at turn 2 as my foot was still firmly on the brake pedal...
You can see from the original pic and the super exaggerated MS Paint job below just how much the brakes were heating up -
BrakesGlowMSPaintEditionlol_zps6f5c4afe.
So Track Day Club on Nov 1 was interesting for all the wrong reasons... Not an ideal day due to some silly things but will get to that... First off i thought i better sort out the front suspension and tyres to stop cooking the outer edges, purchased a set of Cusco camber arms from Jesse Streeter (Incredible service as always :yes: ) and sent the car down to Road2Race for the alignment etc....
b5036a68-eaff-4582-adf4-cde2e05b658f_zps
To our surprise and i will say i guess disappointment we could get no more the -3 degrees of camber from these arms... It was not a huge improvement on where i already was... It seems i will need the lower arms to match to be able to get the desired camber level... This will happen over summer as the car will be having a break (Read that as the wallet will be having a break lol)
I have the same arms on my 34 and can mod them to get more camber :)
Ill be looking to increase the track slightly in the near future as the wheel and tyre combo is already close enough to the inner guards etc... Still interested to know what you have done to yours anyway :)
Going back to the tyre issue... I checked the tyre after inflating it a couple of times during the day and the end result was it still going down... The valves were fine but i think the bead has not seated right unfortunately...
Just to add insult to injury, the final session had cooled down and track conditions seemed as good as they were going to get for the day... I set the tyre pressure high in the hope that it would get to around the correct pressure once i wanted to do a hotlap, it helped a bit but on a fast lap i had issue number 3 (They say bad things come in 3's and they are correct lol)...
I was coming onto the back straight with everything feeling pretty good and POP no more boosts... Basterd!
It seemed to have the clamp and hose in the right spot and didnt look to be loose but it must have been as it has got over the bead that was welded on to prevent this exact issue!
So back to the pits and repaired it and drove back onto the trailer... Not my most successful day out haha
So although it was not an ideal day, it was still a great day out with Track Day Club... A Birthday well spent! Even got a B'day prezzie from them :)
I didn't actually do it to mine as 3deg was all I wanted but as I was setting it up I noticed it could be so you can get one more setting by simple die grinding the main bolt hole a bit
Dodgy mofo :P
Wow, Lotsa update Mat. As said before, was great to be there and catchup again. :)
Happy Birthday too BTW, Kasko mentioned it before we left but by the time we got to Goulburn I clean forgot.
    • haha don't worry I'm sue you've got more fun ahead buying a 30 year old turbo car....but at least you are in the right place to ask
    • some days eh? The keyless entry and interior light on/off with the key will be controlled by the Body Control Module, but I'm not certain where that is or what it looks like (you might get lucky with a search to get a part#, which could be printed on it). I'd start at the A pillar/ Under dash/kick panel on the driver's side
    • It might be hit and miss, but Nissan Genuine Parts and Pitworks are not the same thing, although both are available from Nissan Dealers with Nissan Part Numbers. Nissan Genuine Parts are the OEM stuff, Pitworks are their attempt to get people back from generic parts makers
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
