  • Replies 743
WOW
this is one crazy build. all the best for this mate. not that you need it seeing as you have top quality shops doing all the work for you but WOW.
also the pic in your sic...do you have high res pic i could use as my desktop please?
For the pic go to downshiftaus.com.au and look for the mercury dyno day blog entry. Navigate to the high res image on flickr.
Re: dashboard, will see which pieces survive the development process, then all pieces will be up for grabs
I have Scott Beeton, a former F1 Aerodynamicist working on the design of the aero pieces.
He is currently busy getting the initial geometry prepared for the baseline GTR CFD simulation.
finally got to meet mark today!
after talking to him for abit, i got to say, he is really enjoy doing this.
u can actually feel the excitement from his tone when he's talking about the things they are going to do to his gtr.
Can't wait to see the end result.
And good luck with the Aero pieces.
*in a vin disel voice* not a bad way to spend $150k!!
You sir have just jumped into one of top ten car builds of all time. cudos to taking such a fantastic base and making it even better! Im sure this will stir many jealous souls. the end result should put this car to the standards or if not higher then the infamous mines vehicles.
cant wait to see the results!
please send my condulances to your wallet...but thank it at the same time!!
There's noise restriction on the track!?:blink:
Those pipe look sexy though.
Unfortunatley yes :(
I have to say this is THE only R35 I like anywhere in the world
It has actual development work done and Mr Handbrake doent have the big head of 99% of R35 owners
:D
Yes unfortunately some tracks have noise restrictions, Lakeside is one of them Eric.
Went there last week with the stock exhaust on because of it.
It's better not to have a big head, less chance of looking stupid when you get things wrong.
:D
Mark certainly doesnt have a big head.
But i would say 99% is an very unfair BS generalisation.
How many R35's in the country? 300? i guess only 3 have their head screwed on right.
The rest of us ae dickheads i suppose.
Edited by LSX-438
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
