  • Replies 743
Im pretty sure AMS keeps the specs pretty close to their chest.
thats one hell of a delivery! Its like christmas all over again...until you look at the hole in the account!
I was only watching videos of the alpha 10 kit and black gtr in the US. very very impressive...and that was with the race 3.8 not 4L that you have!!
The turbos have billet front wheels, looks like the Garrett GTX versions, but that is all we know at this stage. With 40 odd cars here at the workshop for upgrades and tuning, plus trying to get Mark's R35 built/finished, we haven't had a chance to pull apart the AMS turbos and measure them up. On initial inspection though, the kit looks fantastic and I would have no trouble recommending it to any R35 GTR owner. Quality is exceptional.
Blocks are cheap. Time isn't.
It's a bored and darton sleeved block from AMS with forged gear.
Yeah that's fair enough, makes sense to buy a prebuilt bottom end rather that strip clean prep etc etc your current long engine.
nice. :) it should turn out very nice. going all 1 piece for the dash or does it need to be sectioned?
likely sectioned centre console Baron
a few things to change on it yet should be ready next week.
Awesome read. Looking forward to seeing the end result. Your really taking the weight reduction seriously. Just waiting for you to say that the roll cage is going to filled with helium or hydrogen haha.
Nice looking build Mark.
Just on the tyre front - I'd be at least trialling the new Hankook Z221 in a 295 - at least until the 295 A050 is available (which I think may possibly struggle on an R35 but would be worth a try given the weight this car should finish up at).
The RE55 is a great tyre and used to be my main choice for heavier powerful cars - but the new tyre technology is definitely a step forwards so would at least be worth a look IMO.
you can never have too many cage pics...
Luke welding up the cage
the entire arse has been cut out of the car and chassis tidied up
Luke will kill me as the rear fuel section cover is not welded in as he would like just yet,
Awesome.
The GTX Garretts have 9 blades not 7 (I think I counted 7), so I wonder what they are.
One question though, how come the plug isnt the inverse of the dash? As in female version? Are they going to make the female from what you posted above?
Or is there some other way of doing it if theyre doing 'dry' carbon? Im only familiar with 'wet' laying so its cool to see how they do yours.
Awesome.
good question. no idea.
will get some updates soon
Awesome.
On NAGTROC somewhere it mentioned they use 3076 HTA Forced Performance turbochargers in there alpha 10 kits and the GT35R version in the alpha 12...
http://store.forcedperformance.net/merchant2/merchant.mvc?Screen=PROD&Store_Code=FP&Product_Code=NTGT3076HTA&Category_Code=Turbo-FP
Awesome.
a plug is the same as the part effectively. it's the mould that is used to produce the parts. you make plug, then mould, then part. :)
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
