Hey Russ if you get stuck i have a r32 subframe sitting at home if you get desperate, needs bushings though, a couple of them are cracked/leaking. Otherwise its had an easy life. Most of the rear suspension is still bolted to it though, but can be quickly ripped off with impact wrench. Also various gtr/gtst diff housing and centre/gears.
Well shakedown 2 didn't go too well. Only got 2 sessions in at PI on saturday
You and me both....although for diff reasons. I went to Sandown and was gentle on the motor for the first two sessions checking knock and temps etc...then the rain hit and out went my chance of a PB :(
No matter as I enjoyed the entry to the front straight ;) and I will live to fight another day!
Good luck with the prep/fixes.
I'm in open class.
Haven't tested a GTR cooler yet coz of the need to modify piping. Lots of time has gone into piping so don't wanna have to redo it if there is a better option. Thanks for the offer though.
well i have just upgraded to a 4" thick core for my car so i have the old "hybrid GT spec" branded 600x300x76 (3" in and out) bar and plate core spare.
though if you are looking for a tube and fin design thats not much help.
Ok. What power has it 'flowed'? what's the length end to end? How much?
Put a STD GTR cooler in it Russ! Best flow kw wise and they actually allow air threw to ur rad which is a big problem with all these crappy aftermarket tube and fin/bar and plate coolers!
Just did similar upgardes to my thing, High mount and GTR cooler now making an easy 320kw and running 30 degrees cooler at Sandown!
Seems like you did okay at winton today Russ, you feeling better prepared for Super Lap now?
Yeah mate. Very happy to get a 1:33.7 at winton. Consistent 1:34's with a turn in understeer problem is great. understeered wide at turn 6 (last right kink before the cleavage) and hit a saw tooth ripple strip. Need another alignment now. It wouldn't turn right properly after that :(
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
