SO my questions is...how mnay people get booted at WRX Sanodwn days because of noise because I havent touched my car since the folly of my first session there the other week when I got booted
There is no way my old GTR exhaust was a noisy as your thing Roy so I was never picked up at Sandown. That being said I have witnessed a few cars like commos get booted so I do know it is enforced...well at least while the EPA bloke is there ;)
  • Replies 163
Posted Images
No need for new tires Blags. Just hit it up with what you have now nyaanyaa.gif
Troy.....heahehaeh
Is this going to be...bet how many laps Troy can do before he gets booted for noise...?
But its such a farking waste of money to go there and two 2 sessions of tyre pressures. Then one session where you get black flagged...if the Scrutineer is sincere then he will ask what you have changed and if the answer is nothing they wont let you run. If they are pretty easy going they will let you go back out knowing you will get pinged the second time.
Need to find a second hand Racepace R32 GTR exhaust .. or just tottle around wasting $ in sessions and then give it a squirt...so hard to improve on your PBs when you only get 4-5 laps in total :(
Spotted 45+ entries, still hoping to enter late and review weather first.
I don’t have to worry about noise but I understand the annoyance of uncertainty, mines the fire extinguisher, relying on rule judgement calls but least they’ve tried to define what is required for 25g force.
THe noise checking isnt done by WRX club staff but by Sandown. So its out of our control.
I dont recall anyone ever being pipped by them on a WRX day.
My noisy friends tell me the idea is to make sure your exhaust pipe that pokes out under rear door is facing away from the EPA guy.
They must have been narked by the epa.. i saw ad in paper for a parttime job monitoring .. i was going to apply, but it might have been a conflict of interest. whistling.gif
Yes you can buy a CAMS license on day from us.
As I said earlier about the fire extinguisher ... i dont expect scrutineers to be checking bolt size this time round. But cable ties are probably out.
Pity I reckon you can build a full race car out of cable ties and race tape. cheers.gif
Edited by Subarau
I worked at the track that was put in at TopGear live at showgrounds.
The drifters did demo laps. I have never picked up so much smashed fibreglass or seen so many panels held on with race tape in my life.
They actually had panels held on with ties that were designed to break and fall off rather that smash them.
Are there any issues with spectating?
I just wanted to do a bit of look-see, talk to people, see how the event is run, see what I need to do before I hit the track later in the year.
Bring cake with you and you will have friends :D
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
