  • Replies 110
Posted Images
it was a great day and it was my first time i would do it all over again every weekend upload more phone and video and if anyone got pic and video of the white r31 gtsx plzzz send it to [email protected]
Yes, the understeer is strong in Cass' R33... at least when Dave drives it :P
Have a few video's of Gimpy's GT-R, Aaron's EVO (including helis) and my car that I will upload as soon as I replace my current video cropping software :)
the day was AWESOME!!! if any1 has any videos or photos of the Silver 1J cressida, can your please upload them? or send them to me? [email protected]...
BIG thanks to all organisers, officials, volunteers, competitors, spectators for all putting on a great day, no problems at all during the day and met a few new faces...
i cant wait to see you all at the next event...
also im interested in drag racing but dont know where i can do it... can somebody please tell me???
lol ha ha ha
Np Terry an Co for the socket set rental. Yes i managed to get everything back except my electrical tape lol. As a mechanic I never leave home without my tools :P Olivia and I had a ball i shall post up a video of all my GoPro footage once i get it and edit it :) Thanks again to all.
If you just need to crop but want to preserve 60fps use this Cass: GoPro Recommends MPEG Streamclip
Vid's up - Dam I'm good!
I have so much footage, I'll try to do another one this week.
http://www.youtube.com/watch?v=LHZf9PJ5XSQ
GREAT JOB for such a short amount of time :D As its already been said thanks to all who helped put on this event and im always glad to be a apart of it. Also thanks to all the competitors who came in the wind and rain and still made it a very fun day looking forward to the next one maby with a Turbo ZED :Di got my hope set lol
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
