seeing as this is all about gym and physique....
Compared to me he is huge. compared to what he could be if he wanted to be, he is 'small'
But like I said, he is exactly how he wants to be and is happy with that, which is what matters. Wasn't taking anything away from what he has achieved and maintained.
Edit: I gave up worrying what people in and out of the gym think. I'm small and get told that by people wearing smaller shirts that can't lift their bw.
They come up to you and tell you your small?
Give em a smack in the head and tell them to wake i to themselves :/
well im a lot lighter than i used to be, but physically bigger and way stronger.
People that dont know seem to need to see fat to look big.
not the people in the gym, just people that end up talking about how amazing they are at curling. generally the people that dont get it.
Im confused by this, are you saying this is you?
If so, props, how long did it take you to get there?.
If not what is the relevance of this picture?
lol nah not me thought it was just a cool pic I found, 3rd or 4th pic looks good I reckon, 5th and 6th is insane!
Agreed, I think about 8-10% is best. Any lower and it looks a little crazy and it'd be too hard to maintain...
This thread is getting massively off topic guys, perhaps we should discuss in the general thread lol.
Maybe we should rename the other thread to just "Diet and supplement discussion" and then start a "Fitness whorethread" for what essentially amounts to an onslaught of spam.
People count cals because some people are not stable enough to know what there eating and if doing alot of exercise they will result in deficent lossing muscle. Then there are people you just know how much to eat of what and are happy and works :thumbsup:
If i was taking as much juice as that moron Zyzz, and i was still that skinny... id have to kick my own ass
Troy I cant belive people idolised that bloke, Its pretty easy to get Jacked up on roids, train all day and then die of what ever condition the silly prick had.
Theres better people to look up to
Zyzz's physique was definitely one of the best for those aiming for a slim look, though pretty well unobtainable as far as we in here should be concerned.
Unobtainable how?
If you're referring to gear, you can get that body pretty easily without gear. Just called a bit of hard work.
Build some muscle, diet properly and bam....there you go.
More than half the pictures posted in this thread follow a similar example of PED use. This is the IDEAL PHYSIQUE thread dude, not the IDEAL LIFESTYLE thread :P Anyone who idolises Zyzz to the point where they condone his methods is a clown and most likely doesn't have strong enough grammar to risk setting foot in the Internet.
Unobtainable how?
Unobtainable because I'd like to think nobody partaking in discussion on this forum would rely on a cocktail of chemicals and synthetic hormones just to change their appearance, and therefore would not be able to achieve such a physique naturally.
It's totally doable natty, it'd just take like 2.5-3yrs of solid lifting and strict dieting. Obviously you won't look the same in regards to long muscle bellies and short tendons (damn genetics) but you would be comparable in terms of size and definition.
I'm not sure if you're serious or not, but I can tell you know, and this from experience and people i work/have worked with, that physique is not that hard to get.....if you are 100% dedicated do dieting that is, which should go without saying.
It might just be bad angles etc, but some of the pics I've seen of Zyzz's muscles I can't fathom being possible naturally...like just way out of proportion...I dunno, just something says so me that no matter how spot on you do things, it wouldn't be achievable without tradeoffs elsewhere.
    • Hi, i’m making Vag coil loom for rb25det, can anyone confirm the wire guage i’m using for power supply in diagram is enough for supply not too small for loom? For earth do i need to follow the same procedure or i can use only 16awg wire for all coil and their connecting wire following to the plug?
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
