  • 1 month later...
hey mate how do you actuate the screamer?
Poke it in the dump pipe?
Same as a normal wastegate; pressure signal from pressurized inlet tract overcomes spring pressure holding wastegate closed.
Open wastegate releases excess exhaust gas (in this case straight to atmosphere, rather than into the exhaust) reducing the volume of gas available to spin exhaust turbine; thus reducing inlet tract pressure and closing wastegate.
The "screamer" name is due to the fact that the unmuffled wastegate is extremely loud; basically like an open exhaust, while the wastegate is open.
I used a turbosmart 45mm wastegate plumbed in before the turbo, it just dumps excess exhaust gasses to stop the turbo shaft speed from increasing once 26psi is achieved.
I have since plumbed the screamer back into the exhaust which made the boost skyrocket to over 40psi, i dropped the controller down but the tune has changed completely, back to the Dyno again...
There must be a hell of a lot of excess gas from the wastegate!
Is it worth (or can you even fit) a larger dump/ front pipe set up to reduce the back pressure? Does integration angle of the Wastegate pipe into the exhaust cause the boost spiking?
Have you seen BOBBYr34's wastegate venturi set up? That wouldn't take long to fabricate... :blink:
post-49633-0-88438200-1313757661_thumb.jpg post-49633-0-58284800-1310467413_thumb.jpg post-49633-0-41323800-1310467527_thumb.jpg
Not telling you how to row your own boat by any means mate; just curious.
Cheers, Dale
They merge at the 4 inch cat body, not the best flowing setup but more than adequate IMO. The reason for the boost spike is the increased pressure in the exhaust compared to just venting it. Once the controller was setup again the boost level was fine but the tune is still out, especially as the turbo spools.
I will try and get a pic today when I remove the front pipe again.
HOLY FUARK how did i miss this thread!
the epitome of AWESOME!!!
i was just talking to my uncle the other day about getting a gigantic turbo for my stag. so it can just be a lag monster.
i can cruise around as if it was N/A all day and then open it up when i want to! lol
LOVE IT!
I never said 500hp is ordinary, it simply isn't a lag monster with a modern turbo and decent setup. Personally I would prefer a slightly smaller turbo for street use on a heavy wagon.
Bolt an old T88 on a 25 or 26 then you will see what laaaaaaaag city is like.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
