christ man, 30kg weighted dips is decent as hell.
hehe cheers mate :D 8 - 10 reps at that weight too ;)
Got a full set of bench dips (feet on one bench, hands on another) with 70kg on my lap too, form dropped off on the last couple though (elbows out).
Yet at the same time I struggle with more than 70kg on bench press. FML
lol farrk, I'm gonna start smashing my arms harder now. 70kg on your lap? How doesn't that bend your knees backwards?
Btw, have you taken girth measurements at all? Curious as to arm size especially after hearing those triceps figures (no homo)
Edited by TM7GTR
Nah I haven't honestly. I'll do that right now...
Both arms measure in the same at 13". Measured with arms straight and relaxed.
DB skullcrushers I can only do 12kg though, haven't tried with the easycurl bar.
Standing easycurl bicep curls my work set (8 reps) is bar +12.5kg each side, for reference to bicep size.
Dunno why my dip strength is so good, when freeweight triceps I'm pretty average.
  • 3 weeks later...
Anything horribly wrong with my deadlift form (at least regarding my back)? 4th rep lower back didn't quite keep up, but was still fine.
Pushed out 2 sets of 3 reps @140kg after this, which is a new PB for me :D
nothing horribly wrong, only thing I'd suggest is to use your legs more (drive through your heels) because it looks like you don't move your legs much
Yeah I agree, sometimes it really feels as though my legs aren't doing much...though the bar does drag over my upper shins as I lift it, then down over my knees as I lower it
Mate your lower back is heading for an injury.
It gets loose as soon as you put pressure through it.
Just before the weight breaks the floor, your lower back, just above the top of your arse, lifts.
It needs to be tight.. Tight as R31 owners.
If I were you I wouldn't be going any heavier till you sort out that form issue.
Watch your vid again.
It's not just your 4th rep (although it is worse than the others), it's on all reps.
Ah yep, I see it. Thanks for that. I suspect that will be cause by me overthinking the initial part of the lift - probably thinking I'm using my lower back too much when really, I'm not keeping it tight enough.
Cheers for the heads up, I'll give it some more shots with video and make sure to get rid of that. Will do it on lower weight of course.
here is another thing to think while doing deads.
Instead of trying to lift the bar up, try to picture yourself holding on to the bar while you push the ground away with your heels.
Sounds stupid but if you do it, you get the leg drive you are supposed to use when deadlifting.
You're movement is somewhere between a dead lift and a stiff legged deadlift where you use your back more.
Back should be locked, legs should drive the ground away from the bar, and hips and buttocks lock the bar in to standing position.
LOCK back
Drive ground away
f**k the bar (as in thrust your hips forward) once the legs are locked out.
Edited by GTST
I'm having trouble getting my head around that - the bar already drags against my shins so without letting my shoulders slump forward I can't think of how to use my legs more than my back. Could you please find a YouTube video that demonstrates it correctly as you're explaining it?
Video will look the same as any other deadlift.
It's a CUE to make you think about what does the work.
good tutorial is RIPPETOE DEADLIFT on youtube.
tells you where your feet should be before you start etc.
I start with my shins about 2 inches from the bar.
I hold the bar, then squat down till my shins touch the bar, lock my back and push with my legs.
The bar just drags up my shins.
Don't know why your shoulders would slump forward when using legs.. they should also be locked with your back.
ok I'll try giving that a shot - I usually have the bar even with the the "middle" of my feet before I lift.
I'm mixing things up a little in my mind, I'm thinking that when you say drive with your legs more you mean have my back closer to vertical before I begin the lift. You mean get the bar moving upward from rest using legs, then towards the top of the lift pulling back at the hips to bring my body vertical?
Feeling good after tonight, up to 40kg DB press. Only 6 then 5 reps, but good enough for me. More than I've managed for a LONG time. Have also pushed up to 30kg incline press...dunno why I'm so far behind there, f**king shoulders lol
You'll probably find it's your back strength lagging behind your chest. I started training my back more with a few different variations of rows, and my bench has started moving again.
40kg db bench is pretty good!
Edited by GHOSTrun
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
