haha I'll change it up a little bit for low carb rest days by swapping out the brown rice for a slice of grainy bread and changing my oats n fruit desert for peanut butter on some low-carb bullshit....but there's never gonna be white bread or anything more than 2-4 slices of grainy bread in my diet sorry Birdman :P
I admire your dedication diet wise. .
I had a medium rare steak for lunch, pepper sauce, chips, vegies, potatoes with garlic sauce, and a glass of American Honey, neat.
0 f**ks given :D
To be fair, that's only a Friday thing...
0 f**ks given :D
Trust me, over the last 2 months the only dedication I've had is to eat everything I've missed out on in the past 6 months - and in ludicrous quantities (hence the 6kg weight gain LOL).
Last night I had a huge schnitzel with chips and salad. Smashed the whole thing (no, that's no a feat - it's showing I ate potato hahaha) and then proceeded to go home and eat a total of 11 weet bix with ~600ml full cream milk, topped with probably about 60g of prunes, small handful of sultanas, 1 scoop BN vanilla WPI, and some sugar free maple syrup. Oh, and some ANZAC biscuits.
0 f**ks given :D
so you probably had around 100g protein, 40g fat and 100g carbs..... Not even half of troys requirements to meet his data. Edited by jangles
I eat pretty well but no set plan, jut smart choices but I've gotten past the ecto stage partly from gym and partly due to slow metabolism due to age.
Back when I was 65kg it was very different.
Keep up the good work Troz!
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
