This is the BEST security you can have If you love your car then,
Microsensor
2-3 Immobilisers
A second car so you dont drive your baby everywhere and leave it out in the open.
A garage
Incase you dont have a garage, have a bat under your bed and if you hear your car chirp which means someone is near it before they even have a chance to do anything you have your bat ingraved into there forehead.
Maybe you will ave a broken window or a stuffed lock. But no way they taken the car.
Can someone tell me how they will take this car ^^^^ other then putting a gun to someones head.
Break into house while you are using second car.
Find keys in the house since they will most likely be in one of the common locations.
Unlock car.
Open garage.
Drive out.
Most common way cars get stolen. Hence why a hidden fuel pump kill switch is the best option.
Unlock car.
Open garage.
Drive out.
this and a steering lock bar, with the wheels turned so they are pointed towards the kerb, less chance of some one lifting the rear axle and towing your car.
it's bothersome, but i use it if i have to leave the car in a shifty place. Just an extra layer of security thumbsup.gif
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
