Very happy thanks Dale i dont thimk think dynosheet has a torque curve but been thinking bout taking my car up to Jezzy boys dyno just for a direct comparison on 2 dynos and also to get a torque read out
Very stout result Mick. You've got to be pretty chuffed with that. My estimate was well shy of the mark, thought the manifold would have become a problem for flow around 320kW.
+1 for graph with a readable scale (rpm on X axis if possible)
+1 also for a look at the torque curve please.
Awesome, I bet it is.... its actually roughly the area I was hoping to see, basically says that its capable of making as much as a stock RB25 with stock manifolds can. With a decent highmount and plenum I'd say the wee GTX3071R has more to offer, too. Definite win for a stock manifold setup, though :)
...on farking corn fuel :) Gone are the days where people are chasing numbers on 98. Come on Caltex, forget Commodore company cars...the performance enthusiast is a bigger market...get more servos stocking it
+11ty
Only 30hp shy of my T67 on a dyno dynamics dyno and by the looks a fair bit better down low :thumbsup:
Makes me wonder how one of these would go in external gate form >_<
PS. Take a better picture of the graph, I can't see shit down the bottom haha
Argh, who starts a dyno run at 3900rpm haha... Makes the curve look so much better than it actually is!
Probably not as good as I thought it was down low compared with a T67, actually may be a tad on the laggier side.
But in saying that it's a very impressive set up for a low mount standard inlet and exhaust manifold set up
Edited by SimonR32
Seriously? A bigger non ball bearing turbo being less laggier?
Not taking away from the results for a second. For a bolt in internal gate setup its brilliant and un heard of power and response 5 years ago. But have to say I am a bit disappointed its not making 200rwkws until around 4,300rpm which is only 200rpm better then my RB20 with a TD06-20G on 98. I am really looking for a 330-350rwkws setup that does 200rwkws at 4,000rpm.
I wonder if something like a Full Race manifold, twin gate and GTX3071R on a std RB25 would do over 200rwkws at 4,000rpm?
Ah ok - if that turns out to be the case this it seems the GTX3071R is a bit like the other GTX turbos, as laggy as (or even slightly laggier) than the next size up wheel would be anyway sad.gif At least it flows more, too!
Can't really be compared with a T67 though, with a 6boost manifold and external it would probably improve by a few hundred rpm in spool and gain a few healthy killerwhats.
Fingers crossed the latest fixes and the 25G make you happier!
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
