Hahahaaaa Scott !! Reverse psychology hey?
On a serious note though....getting the fitment right before I take pictures...will put up a teaser later today.
In other news...got my new keychain from DriftBunny Decals....bling bling !! Crap photograph but looks cool in real life...mini fan blades and all :yes:
Yeah good spotto..Upper arms are next on the list..gktech are out of stock of the v3 ones..dont really wanna get china..played with a lot of setups and stocks kinda maxed out and still looks crap on one side...bent arm possibly im thinking
Ok I need help on this one please.
I am currently running 18x9 +35 with a 35mm spacer to get the rims sitting the way I want them.
Looking at ordering / sourcing some 18x10s but not sure what offset to get.
Apparently the O disk versus the A disk affects offset as well...i want max dish so going with the O disk.
What offset should I be getting if I want the rims to match my spacer set up atm?
Ppppphhhhanks :)
Hey Jez :) how you been? Love the progress. Wide stance is wide. :cool:
Was just wondering, are you happy with the current power set up, or do you have plans of achieving a few more horsies down the track?
Cheers man..yeah all good
Well I will soon have the grip to run a more powerful setup...I already have shiny new custom rocker covers....
So
...e85....front facing plenum...bigger throttle body..bigger turbo and some fun...who knows ;)
Edited by jez NF
  • Like 1
Took a few pictures this evening.....
Have the rears sitting where I want them for now....but new rims are coming from Japland anyways.....three months wait though :/
Fronts will soon have the current rears so will have enough dish finally :)
GTR wing will be swapped back to carbon wing once I get the new wheel setup right.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
    • The rod I was moving left and right you can see looking from the passenger side floor up into the center console.  IMG_8095.mov
