I agree - the number means very little at this stage. There's obviously lots more in it should you wish to push it. Sort out the gearbox & other minor things & see what happens.
In the end it's all about the drive. I'd take tractable, low down power any day over a high end peaky engine with a 'big number'.
Congrats on the tune; as you say, it's less about the number, and more about how it drives.
It was incredibly humid today, and with the temp it's probably not too surprising. At only 4 psi; I reckon you'd be happy with that.thumbsup.gif
nice work! glad its tuned, the power number isnt a big deal, its the torque youll be pulling :)
i agree yavuz is awesome at his job, also a great guy
Well done Alex on getting it to a tune.. has taken a lot longer for some of us M35 drivers :whistling:
Cheers
Andy
Thanks guys- It is a good feeling I have something I can get into, knowing that it has been run, tested, and made safe. Its defiantly very torquey- Jetwreck will share some impressions I'm sure once he gets a chance to drive it.
Who made the call on the boost limit?
HKS Wastegate was set with a spring (or a fart seeing its so light). No other boost control at this stage. Its a pretty nice steady line happy.gif
Good work Alex!
Can we hypothesise on what numbers you'd see at higher boost? 4PSI is incredibly low, as Leon says a lot more in it.
Theres a glass bottom end in his engine according to Craig though, so Im not sure how high they'll ramp the boost :P
Well, just worked backwards using an average of my 2 NA dyno runs.
Every 1psi makes an extra 11.3kw in the current scale. Hardly scientific / precise, but its a start?
Nice. So 15 PSI would be good for 300kW+ using that logic.
True, but isn't that just because Alex needs to bite the bullet...
Needs more Tomei rods - http://www.cipmotorsports.com/tovqcoro.html
Needs more HKS rods and pistons? http://www.nengun.com/hks/piston-connecting-rod-set
SCOTTY- got your package today thumbsup.gif thanks. Hope nothing has melted- pinch.gif
No worries Alex, better get it on quick smart. Change the wastegate spring for a 1 bar unit while you're under there and lets see what she's good for mate. ;)
Was there any reason a boost controller wasn't used as well to bump it up while it was being tuned or is the plan to go back and lean on it a bit harder?
It isn't an exact, but 10kw/psi gains is a good rule of thumb on GT30 based turbos after the first 10psi. Once you are near the limit then it starts dropping down.
My HKS ext gate spring is pretty soft and was rolling over last time at Unigroup.
Edited by wolverine
I just wanted to see it tuned at the base level, before seeing a bit more boost. It also allows my driving a little time to catch up! We didn't have time to mess around too much- Powercruise has these guys working OT. I will definatly be going back to sus out a few things with a few "adjustments"whistling.gif
Was this the same dyno as your NA runs Alex?
Different dynos. I had one NA run at 147kw, one at 131kw. This first dyno is known as very happy (not that I knew that at the time)
Big news is that I have nailed hot start.
Bigger news is that I have my shift back!
And this explains why NM35's are suffering that dreaded delay IE why Jetwreck has to shift at 4000RPM to avoid hitting limiter. The ECU talks to the gearbox in 2 different ways- First "calculated load" which is very basic: At RPM points what base fuel schedule is seen at WOT. Secondly a map called "torque management". This is a table that compares RPM and base fuel schedule on the axis', and the numbers in the table equate to the line pressure in the gearbox. Because we reduced the base fuel schedule to around 12 at Max noise this table was waaaaayyyyyy out. It was expecting a BFS of mid 20s at max, so the line pressure would never harden up. At the moment, I'm just using the max as set from factory, and have moved it to the appropriate section of the table.
Shifts are clean and crisp without the massive delay.
This is why NM35s have trouble with the tiptronic once you add some more power in there. The computer isn't expecting to see the BFS the way it does, and then doesn't have an appropriate line pressure to suit when you ask it to shift. Its not a replacement for the transgo kit, because that is needed to hold the higher pressures.
Its wet everywhere here atm, and after doing that, in rwd the bloody thing spins up the first 3 gears!whistling.gif
Edited by PN-Mad
Nice one Alex.
If I understand you correctly, it's not the making of the extra power that buggers with the gearbox shifts, it's the fact that much bigger injectors are being used? The base fuel schedule essentially works off injector pulse width, correct? So when adding bigger injectors you reduced the numbers in your table (to about 12 in your case) to get the fueling right, but that played up with the corresponding relationship with the gearbox computer (that was expecting numbers like 20).
Aren't you lucky to be able to delve into the programming.... aren't we (NM35 owners) a little bit screwed then, lol. Well not me as yet, just you other guys with the big squirters. There's a way around it tho, I'm sure.
:cool: re the wheel spin. Care required in the wet by the looks of it.
Edited by Commsman
Nice one Alex.
.....and that pretty much explain's why my shift to third is very indecisive when the E-Manage and bigger injectors are in.
mind you in Drive the GB seems to shift and sort its self out a lot quicker
Edited by Jetwreck
Alex, I presume you can see/modify all of that information in your Uprev software?
If so, looks like I need to get me one :)
Yup- its a good bit of kit.
Nice one Alex.
Correct- its the Injectors that make it instantly rooted- because of the reduction you have to make in the K fuel multiplier, and therefore BFS
HOWEVER- I would say that when you play with a NM35 and make it come on a lot stronger earlier (ie dump, exhaust, intake pipe etc) I would say that that would have all kinds of dastardly effects on the BFS (and this is why you get really rich- it goes into high BFS, low-mid rpm which it will dump fuel). If you see mine, its sort of like the dyno graph- ramps up and then levels out at about 4750rpm. so the last 4 values in my calculated load table are actually all in the 12's BFS, even though we go from 4600 to 6000 rpm or something.
Any of you guys using aftermarket computers able to access torque management?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
