kunts suggesting FDs then putting me off em :down:
if you were to trade you would complain about owning an import again, i can forsee this
could be driving a veyron and i'd still complain. no such thing as perfect
found another dude with a mint black m3 127ks willing to trade + 10k on top i'll go check it out this weekend
just take your turbs to HG..ask for a rebuild..under 1k ..bolts straight in with no mods, will last you years and handle more boost than the stocky..
or get carried away and start spending $$$$$$$$
+1.
Got link Barbs?
Didn't know 34R's were that cheap
Sounds hard to believe but THERE WAS a 1999 GTR V Spec in Blue with 90,000km's in NSW for $36k, just last night... looks like he took of.. unless he sold it recently or was made aware of this thread? :blink:
You can always haggle some one to shed off few thousand from their asking price
Otherwise the cheapest is listed for $39k
http://www.carsales.com.au/all-cars/private/details.aspx?R=10994583&__Qpb=1&Cr=0&__Ns=pCar_PriceSort_Decimal|1||pCar_RankSort_Int32|1||pCar_Make_String|0||pCar_Model_String|0&keywords=&__N=1216%201282%204294963593%204294963846&SearchAction=N&silo=1011&__No=60&seot=1&__Nne=15&trecs=1034&__sid=1332B5B7F544
A good salesman will buy that for $35k
Edited by Flynnn
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
