Lol yes srsly. i'm just trying them out. i liked jura superstition though. was different. they're all pleasant to drink, and that's what counts.
not really lol... have you tried Laphroaig? it's an overly peated scotch that seriously tastes like a burnout.
it's is very much and acquired taste and while i do not suggest that barbs doesn't like it, as plenty of people do, IMHO it is shit and there are better options around for the money.
Birds is using something he is happy with. But Motul Gear FF 75-90 or Redline Heavy-Weight.
Motul Gear FF 75-90 is the EXACT oil nismo supply with the diff (but nismo branded)
I use Motul Gear Competition 75/140 and the diff hasn't been happier. locks harder and faster, makes less noise
id me a smooooooooooth kent.
Interesting...
Thought you'd dump her in some lake I'd never heard of and make her walk all the way or doing skids outside her place.
oh that bad?? lol. okay then i'll get something else.
i wanna go for a drive but cant, i did my back and cant move :(
did anyone read this? it doesnt really explain what it is. it sounds like something you would find on ebay.
http://www.heraldsun.com.au/news/more-news/brocks-energy-polarizer-makes-a-return/story-fn7x8me2-1226173968082
They te37 superlaps
Ditto. The specs on this black 33 is 17x9 +22
Buying super laps might make your rims worth 1/2 your car brah
Yup, they're not cheap at all.
Lol barbs you wanna buy TE37s, but cbf spending 500 on tyres and you're looking at eBay turbos?
My brain is full of f**k
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
