Best track car went to SIKJET...the white 33r with all the carbon and such
lol i think i may have been at the wrong SnS :domokun:
I thought the blue car was the pace car.
So I was doing the slalom with you to warm up the tires :D
:thumbsup:
lol i saw that. but the guy behind you wasnt doing it.. so i didnt wanna do it and look like a dumbass by myself.
haha s'all good, next time :P
theres a pic of alex + mrs, aaron + mrs and i all in the car, full car load ready for chaps lol
so I did meet alex? he was in the front seat yeh?
lol @ no one letting you sleep hahahah
lol thanks dude! i spoke to GTTr34. he said he thought he won it by default as well(I wanted some parts off him)
so i dont know what happened.. shouldve stuck around. oh well
Ash even made the hint when i asked him if ill be alright to leave.. gave me this cheezy grin and said what if you win?
Should have stuck around indeed :P
I didn't have any involvement with the judging - totally independent so people couldn't say "favouritism" etc
But if you left - no trophy/judging for j00! :D
yeh I know who it is now.
33R with the nice wheels.
im pretty sure I was the resolver of that grill any way.. trying to take the credit here.. but I got it off!
Alex's car looks like an R but it ain't :D
you make me die a little inside.. lol
oh. fooled me! looks nice. if his wheels ever go missin dont look at me :P
Should of had something going on along with the SnS. A lot of people got bored of looking at cars quickly.
I saw some rubber on the tarmac, maybe some skids? ;] :P
lol or boobs
yeh he was in the front.
f**king, i was so tired when i got home. parked the car in the drive way and just sat there for a few mins. lucky my house is like 2 mins from the cooper street turn off lol
Moh.taxispec
Ahh back finally ..gawd.. 3 nights worth of hangovers.. so tired
Spotted you on the way back Nick :)
-_-
you also did the dodgy laugh and ran off to me before i left LOL
oh, and you guys missed out on birds singing arab music.
yeh you dissapeared.
lol and I could almost imagine what he would sound like..
Haha yeh u met me man !
Nah no R here need rwd so I can be a pro drifter
ahhh yeh sorry dude.. i got abit confused with all the names lol
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
