Your issue might be sorted, but the issue of me not being set up on a date with this girl remains unresolved. Solve the issue Aaron! Tell her dad that I can set her straight :)
I want a blackberry. its hard to type with touch screen without looking at the screen.
also typing when walking.
@aaron. meh. i averaged 4/10 through out the whole ear. thats how bad i am with english. hahaha
I threw a blackberry out today at work - was taking up draw space. :nyaanyaa:
