Ovacast like a maafkr out there :( Still warm though :)Cruise last night was fun, good to meet some of you guys :)
No cats on the road tonight :D
+1
Special mention to Grant from the Wastelands for coming out last night. Can now understand where your coming from when mentioning social interaction. And also nice to meet you and hopefully will again in the future :thumbsup:
+2
Thanks Michael for coming, tried to say hi to everyone. But a bit hard when everyone is 'Come at me bro'!
No worries Tony, but had fun driving even though everyone is going bit slow for my liking.
agreed. was hoping to push it through arthurs seat but i think there was just too many people..
Lol some of the turns though man.
You might have ended up off the mountain if you guys went faster :P
no chance lol i was tailing you most of the way, one turn im pretty sure i got bored and over powered lol
i didnt know you were there until you left! shame didnt get to meet u
Ah, saw your car but don't know which one you're amongst many people.
Yeah, anyone got held up by the bus on the Esplanade?
I think I probably held everyone up on the uphill :/
Yes you were! Bolt a turbo in it next time you go there.
There was a cruise last night??
Farrrrrk!!!
Yep...
Really?
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
