hahhahahah i think the same thing. but i havnt taken her out in a while so i thought i may as well suck it up
I sat through this shit when the first one came out to get into the pants of some girl who was obsessed with the books. It really was not worth the shitty emotionless acting.
Lol
WTF is up with village charging a booking fee online!? It's more expensive to book online and print ya own ticket than to go to the booth where they pay staff? Go figure.
And gold class is like $5 or $10 booking fee eachticket Online
yup. used to be muy cheap for me cos a mate used to work at knox goldclass
lol yeh thats where im going
Lol
yeh no shit i saw that. but i didnt really have a choice, if we were to line up there wouldnt be any tix left. im suprised at how many retards like that shit.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
