Thought just occurred to me, how am I going to wipe in dark?
Only my street is in total darkness, elsewhere have electricity.
Don't need to look where you wipe man, should be 2nd nature to you now.
not like you can miss grant..
Yeah... Trying to find the cistern itself in dark is a mission by itself.
Thank god for iPhone, it doesn't just do normal mobile phone, it's basically part of your life when you still have the charge.
Havent been here for a while to know what the go is:
breif summary on flynn would be good LOL
Any body else using a HHHD button clutch? Lol will the harshness go away after a while or not
took me bout a day to get used to.... now it's normal to me
Die in a fire
I had to take my US trip on a credit card and looks like i might have to do the same again when i go in the next couple months :)
since you spent your whole trip in an internet cafe telling us about it, why not just throw on a Hawaiian shirt, go to an internet cafe in melbourne and pretend....
it'll cost less and we will all give just as few fucks as last time
Yeh I'm starting tO become custom to it.. Stalled a few times but should be better once it's broken in and I'm used to it
Lol
What a nice beautiful day, eye candy galore.
So who's going to the cruise tonight? Or am I the only wastelander?
Am tempted to come to the cruise, may proscanting the assignments til sat arvo, also have someone to look at the GTR tomorrow.
Come and say hello and check out the cars, then go home and study if it doesn't excite you?
How much you selling your GTR for? :ninja:
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
