Nar the one from CQ, the one who walked up to the hottest girl in the club and basically said "this guy wants to have sex with you".
Haha how could I forget! Imagine that kent squeezing into the back of my car, yikes
Fo'real. And Bruce Willis was dead the whole time. It was an Amish-like community set in modern times. The glasses of water had a purpose all along. Samuel L Jackson was behind it all.
parking + traffic issues would be solved i'd assume. but still rather a roof over my head so it would be more of a "toy" kinda thing for a sunny day
no harm in getting the license though...
Yeah would only really be a summer/nice day thing for me too...
Don't see the point in getting the licence if you don't plan to own a bike though, can think of better ways to spend $3-$500
Rent bike, ride to Moto GP at Phillip Island = win! Just a handy thing to have in case you decide you ever want to own a bike...that way you're not waiting a year before you can get something powerful.
Yeah not a bad way to go about it, but unfortunately I think I'm smart enough to realize that I SHOULD start on 250, just can't handle how gay they look (or justify spending the money on the decent looking 250's only to f**k it off 6 months later)
But yeah don't think I'd ever get the license just to have in case I decide to hire one for a weekend to hit the motoGP..
My mrs did say she'd buy me a gixxer/R1 after we've been together a year which only fuels the desire even more lol
Hey Dezz u going f1 next year? I'm thinking about it not sure which package/position I should be going for my mate said the chicane
Don't even know what I'm doing tomorrow, but I may go...Used to go every year but haven't been for the last 2 I think... Never been in the grandstands either so can't really help you there, but would probably get a grandstand package if I go next year..
Without having sat there myself, and not knowing the names/positions of all the stands without pulling up a map, I'd imagine sitting at the turn 1 chicane at the end of pit straight would be good, especialy on the first lap and the few laps after that when it's still relatively close.
Sitting directly across from the pits would be good as well if you're into F1, seeing all the pit crews etc at work.... Pretty sure all of the stands have a big screen within view of them as well, so you get the best of both worlds..
R1 for 1st anniversary wtf? You said she was well off but f**k...
Lol think you've got me confused with someone else...Never said she was well off, just that she's awesome lol
Alex, PM Bris, or ctjet even, think they've both been and sat in the stands...
or Do-Luck if he's still on here....Anyone know if Shane is still alive ? lol
I sat at the qantas stands. First set of seats at beginning of straight. Hired the little portable tv which allows you to choose differnet camera angles. If you got one of those tv's or good view of one of the large screens, any grandstand position is good :P
One of my clients does packages on the grandstand down the main straight on the 1st corner.
Can get prices for you if you want. Pretty pricey but then again you are a high rolla :D
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
