Ohhh the names with which people are familiar... so, not the influential ones then? I see.
Better luck next time n00b
Daft Punk (duo),Cassius, Groove Armada from 90's are pioneers of House/Electro House music phaggot, they shaped and influenced hundreds of other producers of todays.
When was the last time you heard a Booka Shade or a Fedde Le Grand set matey? Should follow my contemporary electronic thread in wasteland closely...
http://www.skylinesaustralia.com/forums/topic/243036-contemporary-electronica-thread/page__st__420
Fuck these number plate selling cunts shit me, "offered a lot more in the past", bullshit. If anyone buys them for more than the $500 they're worth, they are an idiot.
Hmm found out why my rear seatbelt won't work anymore, part with the spring in it has cracked and come off. 2 door 33 seatbelt mounting points the same as 4 door? Otherwise where would I find a Klippan PDO18 seatbelt.
Grant why do you want such a loud exhaust? Can you actually hear it if it's mega loud or does it make more/bigger vibrations? Not worth it for the EPAs dude.,,
This, and help idiots see me in car park... Too many idiots can't look where they're going in car parks.
f**k these number plate selling dream boats shit me, "offered a lot more in the past", bullshit. If anyone buys them for more than the $500 they're worth, they are an idiot.
it also doesn't make sense to me, paying $500 for custom plates on shitboxes like lancers, and xcels, like, REALLY? that plate is worth 20% of the car mang.
Get a Varex twin tip...I'll show you mine on Sunday, it functions quite well...quiet mode for daily driving and loud for your carpark driving etc. I can feel the difference in vibrations between quiet and loud. Looks a lot like the factory twin tip so I never get trouble from police over it. Put that on a straight pipe with a cat and you'll have a nice sound/vibration :)
Don't want factory looking exhaust, I want polished cannon.
Might find out if my old exhaust is still for sale.
^^ This!
But I would not even pay $500.
Custom plates are the biggest load of bullshit when it comes to selling them.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
