My Friday night story:
A rather pretty girl walks up to me in a bar and asks if I play Xbox. Totally catches me off guard (what the f**k is this shit Charles?), I have nothing. Confess to playing COD occasionally (more like, an hour a night), trying not to sound too nerdy. Then our ice breaker conversation revolves around how annoying campers and snipers are in MW3. She writes her gamertag in my phone and tells me to add (what happened to phone numbers?). The girl is a network admin, which explains a lot...and now I feel a little bad because, thinking about it, this is probably some IT guru's wet dream, wasted on me. Meanwhile, old mate was staring on in disbelief and has now lost his faith in humanity. Me, I'm in two mindsets: A. Lucky motherf**ker, you just picked up with the aid of a video game, how often does this happen...or B. It's a strange new world.
Must be cause you're f**king chiseled brah
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
