Sucks to be at work today! Beach is awesome :nyaanyaa:
dieinafire
Birds, I'll change the rego label for you to wax my car?
Negative.
fkn lol.. scared of a short are we?
It's grounded you twat. I just want my stereo back.
LOL!
On another note, Commodore engine bay are piss easy to work on. Changing coilpacks can take me 15-30mins tops, but my brother, it took him 20 mins figuring out why the plate won't fit on his until I came and took it off and out it in the one already bolted into motor.
If you're not working and not at the beach already, then you're too crazy to join me :closedeyes:
Got a rental property to look at this arvo after work, otherwise would vato loco :P
Barbs would get there and update us on the racial demographic of the beach populace :P
Lulz, too true. Not to mention i'd get crisp burnt
Lol Birds
Also RBA have announced an interest rate cut, F*ck yeah! Now for the banks to pass it on!
Interest rates in US are at 3.5%, half of ours.
Should defiantly get down to 4.8% like it was once at. Good for borrowing, not so god for saving.
Edited by Flynnn
Customer trying to convince me that Harvey norman in thomastown quoted him below cost price for a Goldstein electric range.. Dikhead they don't do commercials.. And we're the only Goldstein reps in da north
Should have pulled the Y U LIE TO ME FOR... move on him.
http://troll.me/images/y-u-no/buttwhole-y-u-lie-to-me-thumb.jpg
you do realise the current fed rate in the usa is something like .25% ?
do you know anything about the shit you spin or what? do you realize how bad that is for there economy?
Rates dropping are a negative sign not a positive one, it means the economy is going badly rising rates mean its a strong economy..
I'm quite AWARE where we're heading hence why I'm renting :P
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
