Sucks to be at work today! Beach is awesome :nyaanyaa:
dieinafire
Birds, I'll change the rego label for you to wax my car?
Negative.
fkn lol.. scared of a short are we?
It's grounded you twat. I just want my stereo back.
LOL!
On another note, Commodore engine bay are piss easy to work on. Changing coilpacks can take me 15-30mins tops, but my brother, it took him 20 mins figuring out why the plate won't fit on his until I came and took it off and out it in the one already bolted into motor.
If you're not working and not at the beach already, then you're too crazy to join me :closedeyes:
Got a rental property to look at this arvo after work, otherwise would vato loco :P
Barbs would get there and update us on the racial demographic of the beach populace :P
Lulz, too true. Not to mention i'd get crisp burnt
Lol Birds
Also RBA have announced an interest rate cut, F*ck yeah! Now for the banks to pass it on!
Interest rates in US are at 3.5%, half of ours.
Should defiantly get down to 4.8% like it was once at. Good for borrowing, not so god for saving.
Edited by Flynnn
Customer trying to convince me that Harvey norman in thomastown quoted him below cost price for a Goldstein electric range.. Dikhead they don't do commercials.. And we're the only Goldstein reps in da north
Should have pulled the Y U LIE TO ME FOR... move on him.
http://troll.me/images/y-u-no/buttwhole-y-u-lie-to-me-thumb.jpg
you do realise the current fed rate in the usa is something like .25% ?
do you know anything about the shit you spin or what? do you realize how bad that is for there economy?
Rates dropping are a negative sign not a positive one, it means the economy is going badly rising rates mean its a strong economy..
I'm quite AWARE where we're heading hence why I'm renting :P
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
