Sucks to be at work today! Beach is awesome :nyaanyaa:
dieinafire
Birds, I'll change the rego label for you to wax my car?
Negative.
fkn lol.. scared of a short are we?
It's grounded you twat. I just want my stereo back.
LOL!
On another note, Commodore engine bay are piss easy to work on. Changing coilpacks can take me 15-30mins tops, but my brother, it took him 20 mins figuring out why the plate won't fit on his until I came and took it off and out it in the one already bolted into motor.
If you're not working and not at the beach already, then you're too crazy to join me :closedeyes:
Got a rental property to look at this arvo after work, otherwise would vato loco :P
Barbs would get there and update us on the racial demographic of the beach populace :P
Lulz, too true. Not to mention i'd get crisp burnt
Lol Birds
Also RBA have announced an interest rate cut, F*ck yeah! Now for the banks to pass it on!
Interest rates in US are at 3.5%, half of ours.
Should defiantly get down to 4.8% like it was once at. Good for borrowing, not so god for saving.
Edited by Flynnn
Customer trying to convince me that Harvey norman in thomastown quoted him below cost price for a Goldstein electric range.. Dikhead they don't do commercials.. And we're the only Goldstein reps in da north
Should have pulled the Y U LIE TO ME FOR... move on him.
http://troll.me/images/y-u-no/buttwhole-y-u-lie-to-me-thumb.jpg
you do realise the current fed rate in the usa is something like .25% ?
do you know anything about the shit you spin or what? do you realize how bad that is for there economy?
Rates dropping are a negative sign not a positive one, it means the economy is going badly rising rates mean its a strong economy..
I'm quite AWARE where we're heading hence why I'm renting :P
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
