Hrmm wanna sell the headlight spacers? That's the part I need lol
Nope :)
Wheel tech do really good work they in dandenong
I was not impressed with the work performed.
I've gotta get my wheel redone as a result
Always Powdercoating off Gatwick Rd in Bayswater...got some scratched up S15 alloys coated there and they looked factory brand new. Was about $45 a wheel? You can't always get the coats perfect / completely scratch-free, but you'd struggle to tell unless you examined up close.
I don't really need powder coating done I really want the outer lip polished properly. The car used to sit in one spot for months and you can see the corrosion from where the rain would sip and drip out. If someone wants to polish for me and give it a shit I'll be happy tried autosol with a drill but didn't really do much
Nerds are underrated. I'd stickerbomb the car with pokemons and drive around with an Ash baseball cap on, shouting out sleazy puns at P platers in Lancers.
Rofl.
There's a car with the plates EDBTZ,
Means My hand is in my ass. Lol
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
