Reminds me of the one and only time I went to a LAN party... all my nerdy mates were dominating me at CS, so I ragequit and downloaded Wolfenstein... shoulda seen them all huddling around my computer after that
I don't know who you are. I don't know what you want. If you are looking for ransom, I can tell you I don't have money. But what I do have are a very particular set of skills; skills I have acquired over a very long career. Skills that make me a nightmare for people like you. I will look for you, I will find you, and I will kill you.
Command & Conquer & Red Alert. Quake & Quake 2.
Wishing I had a Voodoo graphics card or 2 in SLI. Those were the days :D
On another note there is a cruise down to Arthurs Seat tomorrow meet at Box Hill organised by Zero Exhaust if anyone is interested.
I received a free legit copy of Quake 1 with the purchase of my 33.6kbps modem.
People be mirin it over their 28.8kbps modem.
Then the 56kbps modem came around and that was serious business!
I got Battlefield 3 for xmas, its just not the same as the good ol' days... :(
There'll be a 35R there. I waned to go.. Fkn Sydney is so boring
I remember having 'freenet' or something like that back in the quake team fortress and early CS days...
Was 100% free 56k internet, only condition was a small banner that stayed open, but was hidden when playing quake/cs etc.
Used to lose it when I had to d/c for someone to make a phone call though lol
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
