went to exhaust place today to get some pipe for intake, they noticed i had a factory system still on (is factory but decat with varex copy twin tip) but because he recognized my old man (did exhaust for his merc) he asked me if I wanted to get a full 3" turbo back system with hi-flow cat made up and installed for $1k as "mates rates". This good deal? :laugh:
lol mates rates...my turbo back 3" was $600 with me supplying the cat and varex end muffler. Mild steel with mandrel bends. Don't bother with stainless it looks like ass after a year anyway and mild steel sounds better :P
It wont work with larger injectors.
You'll need to configure them within the PFC at a bare minimum regardless, or it will just over fuel and stall, it might not even idle.
This Birdy. It's a piece of piss to do, should be in Paul's faq
really? how does surface rust look better :P
fml. did Rev210's 5min $5 intake pipe mod and i just took my car for a little drive and it drove like shit. held boost fine but didnt go. before mod it went fine. HELP!!!!!
took off ic piping from turbo and return flow to get better access to rubber induction pipe, unplugged and took out afm and pod, cut induction pipe and inserted 3inch diameter/12cm long mild steel pipe, placed piece of pipe that was cut off back on and both side are secured with metal hose clamps, plugged in and insterted afm and pod back on, put ic piping back on.
Just some extra info: battery was disconnected when this was undertaken, Rev210 says to remove whole induction pipe but i left it in because the clamp for the plumb back recirc pipe was impossible to get off so i cut it while it was in the engine bay.
**EDIT**
Link to Rev210's guide.
http://www.skylinesaustralia.com/forums/topic/173019-rev210s-5min-5-intake-pipe-mod-for-your-stageaskyline/page__mode__threaded__pid__4756582
Edited by JDMKiD__/ⓞⓞ-33
Any wastelanders going to the photoshoot meet/cruise tonight?
I might head down for a bit
just around the corner from my house saw mr.P pulling over some Mitsubishi and searching his car! His partner greesed me off as i drove past. Afraid to leave house with 32 now haha
I was thinking of going down and getting some photos.... dunno if i can be bothered though... dunno anyone whose going down either really...
Got to start somewhere. I'm sure many a people didn't know anyone at their first meet
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
