Mixed too.
Lambs on Commercial Rd, next to the gay bars :)
double lamb all the way, never seen one under $10 - with decent meat.
Stalactites for instance, half the Souv goes in the bin as it's just chunks of fat. Fken terrible >_<
Stalactites are awful, I don't know why people rave about them. Meat cuts are bad and huge chunks too. I love my lambs because they are small pieces so easy to eat and always good quality meat...has to be Commercial Rd Lambs though. The rest of the Lambs along Chapel St, not a fan...similar to Stalactites. Give gay Lambs a go and see what you think...they do double meat but I don't know the cost. It's about half way between Punt and Chapel.
I'd be curious of the predominant thought process when girls wear leggings/jeggings out.
1. Because its comfortable
2. So all the guys can stare at my ass
3. Because they fit easily in motorcycle boots
And they are comfortable :closedeyes:
Edited by JEPPE
ROFL @ Gay Lambs love it :D
I don't mind big chunks of meat (hohohooomo), it's just piles of fat I cannot stand. I mean of course lamb is a fatty meat and hence where the flavour comes, but Stalactites is 100% woeful. Only thing is it's walking distance from work @ 4am and is open on a Tues night etc.
I'll drive to work on the w/e though so will give that one a crack on break.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
