tripod
long exposure
and a trigger flash light
you can see in the 32R shot a ghostly blue figure on the far left
that would be the guy running around the car holding the trigger light next to so that the light floods in
Correct, was running around with a LED torch.
tripod
long exposure
awesome thanks.
Ive got a tripod, ive got a dslr, just need the torch and some skillz
Need to google some tutes
Lip and skirts and maybe another lip for more low
haha i parked on the point of the hill so i could get under the front bar easily. When on flat surface i imagine it will be quite low...probably too low to get up/down the driveway or in garage haha :/
cheers all for your critique. Will take it on board and let you know. Keep it coming (about the car that is :P)
The frontbar lip needs to be re-clear coated (unless i can fix it with a polish)
Recent one was a finale? o_O The double ep with them on the beach in the end? o_O
yep. show finished :\ it could of gone either way.. would of been nice to know the nice guy gets the girl :(
I'm sure in everyones head she has a flashback and remembers lol
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
