Yer it's the bacteria that starts eating away at the flesh if you don't attend to it soon enough. When I woke up it was smaller than a mosquito bite, then progressively turned into a puss volcano. At it's worst all the tendons inside the hand were bruised as shit and it hurt just to move my fingers. Attacked it with oral cephalexin and topical bactroban, which are doing wonders...antibiotics ftw.
Yep necrosis is nasty shit. Look up pics of brown recluse spider bites if you want nightmares...thankfully these are confined to the Americas. But white tail bites can end up pretty bad!
So did you feel the bite considering your were sleeping?
Or wake up like that?
Do you know look around your house and under your sheet covers before you go to sleep now? :D
Now I'm going to be slightly paranoid when I get home :/
thats one hell of a hickey.
looks like
that spider
gave you..
a hand job
YEAHHHHHHHHHH
gotta teach my warehouse worker how to deal with customers, selling techniques etc.
quick as learner!
Just woke up with less than a mosquito bite...didn't even scratch it until the afternoon. Things went a bit downhill from there...
Haha nah not para about it, although I did see a baby spider on the missus a couple of nights ago...so the female that bit me could have laid eggs somewhere.
R33 GTS-T? Nah man, disposable diffs. We only sell reco stuff and it's not worth the cost of recoing unless you're putting in a mechanical LSD centre. Buy a second handy on eBay for around $150, $250 if you have ABS.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
