lol i linked it coz it looks good not coz its the fastest learner legal bike! not really interested in speed at this stage, dont wanna die just yet lol
Ah okay, meh...9k for the looks is a bit :/
Kawasaki have like 11ty different models of 250cc bikes, should be able to find a Jap 250 you like the look of.
Aftermarket kit by Tyga, stock looks like this. Also available for other models
Had a f1 sounding late 80's bike pass by the other day, sweeeet
Is anyone a really experienced in electrical stuff with installing gauges. A very experienced auto elec spent all day trying to get my autogauge gauges to work but in his opinion all 3 are faulty.
Had no problems wiring my mates ones on the same day. His gauges are a different type so couldnt interchange to test.
Will pay monies if anyone can fix it ASAP otherwise I'll just email just jap Monday morning to discuss the issue :(
My dad owns and runs an electronics repair business for 30yrs. Can have a look at it. Let me know it free tomorrow we can have a play around with it. In dandenong. Pm me for more info
Hamish I didn't go to the dyno day I went to cihan for a tune.. The cars timing was out by 10 degrees I'm suprised I didn't break something..
I'm running a Hks gtrs or whatever they're called runs like a dream now..
Only thing is there are custom wade cams are massive, so the mid range is abit flat. I think the motor was built for a massive turbo
That's pretty responsive for a gtrs on a 2L isn't it? Must be good fun now!
hmm seems a little low for a gt-rs.
I would expect closer to 250, what supporting mods do you ahve for it
PM sent! :thumbsup:
Did u get the stepper motor ones?
You have to wire active (red) and one of the colour (orange or white)to positive and black to ground. The orange and white is the colour of the lights.
Ya the purple s14 with CAMS and GTRS made approx 250 on chasers dyno today.
But i think aaron runs the standard airbox?!?!?
Hey John,
Yeah I got the Autogauge Shadow Pro series. Stepper Motor Series.
Red is wired to constant power. Orange to accessories, yellow to lights and black to ground. Everything was done by the auto electrician as per manual.
They all turn on but are not reading anything through the sensor. Also the water and boost gauge flash intermittently showing something is wrong.
But everything has been wired correct and checked by two seperate people :/
Have wasted a whole day on this....
Hey John,
Ah I didn't try em that way.
Wired both into accessories. Off the back of the sig lighter.
Josh did the same with his 32 iirc
That is the stepper motor series tho
Yeah my mate bought the autogauge stepper series and installed without a problem today :(
Though he wasn't sure where you put the aftermarket oil sensor.
Where did you put yours? Any fiddling around?
pretty sure you screw your oil filter onto a sandwich plate which you connect your oil pressure/temp sensors to. no?
mmm very nice!
Edited by R-SPEC
yeh it is but ill explain below why
its a GTRS high flowed into an s15 compressor housing.. so its not up there at 250 flow wise, but its a hell of a lot more responsive than it usually is.. Cihan said there was definitely more power he could get out of it, but i didnt want to push it.. im happy with 230kw in a car that weighs half as much as the stag lol
yeh sort of. i have the bottom of the airbox shaved off though.
i wouldnt mind chucking it on another dyno to see if there is a differing figure.
mmm very nice!
Cheers Rimon
On the topic of bikes. There was a pack of bikes on princess hwy frday night doing wheeles & burnouts @ 100km/h..... :mellow:
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
