lol I was just looking at some houses on realestate.com.au and a lot of the photos were taken with sun shining through the windows into the houses and no furniture, makes them look VERY hot to walk through, even today.
So damn cheap, someone buy it before I do something stupid:
http://www.carpoint.com.au/all-cars/private/details.aspx?R=12171585&__Qpb=1&Cr=10&__Ns=pCar_YearMade_Int32|1||pCar_RankSort_Int32|1||pCar_PriceSort_Decimal|0&keywords=&__No=15&__N=834%201216%201246%201247%201252%201282%204294966879%204294729565%204294967079%20447&SearchAction=N&silo=1011&PriceTo=447&seot=1&__Nne=15&trecs=105&__sid=1355711DA55E
Mmmm M3's.
Last night saw Aaron's friend with the convertible E46 M3 convertible. 11 inch rims on 235 tyres :/
lol just saw that it's in QLD, looks like I won't be inspecting it on a whim. Still, anyone serious about buying one, that sounds pretty legit...cleanest I've seen for a while.
Disagree re: r32 plan
Harder and harder to find a r32 which hasn't gone down the cheap thrashed path. It is better to see a clean r32 than some cheap and nasty with power because that power is nothing spectacular so it's lose-lose.
My opinion would be to restore a r32 gtr but 4dr's provide a different view
Good luck with the rebuild, in 5-10years time when everyone has moved on to their family/boring cars you will have something which wasn't discarded because of the cheap thrash mentality.
Similar example; look at all the kingswoods being restored. Everyone looking for shells including the basic 6cyl models.
Tl;dr
Also, I just love r32s.
It's like when people do up those old rotors. They're shit. But in the end it's up to the owner.
I'm doing what I had planned for my first r32, only rwd and with a sun roof :)
Hey pat... Sunroof seal is integrated into the glass.. And they don't make them anymore. FML
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
