pulled the rear window off to get a better look at that rust spot
only the size of a 50c piece
ricardo wanna be all hard yakka again and come past and give me a hand rippin that motor out? need your little arms to get in there and undo some bolts :P
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
