i did and then quit in the same day.. lol the job was a for a team leader position for twice as much pay.. and then turn around and say thats only a possibility after 6 months. i f**king flipped.
what do you mean for no reason. they said it was a 60k STARTING WAGE.. ended up only being 27k.. how is that no reason?
i turned down two other jobs at the 60k rate because I got this one.
How's the gearbox treating you Aaron?
perfect bud. everything is so much better.. done about 400km so still running it in
27k? lol what kind of job pays 27k?
domestic first years probably make that lol
was some sales shit at a marketing company.
no i meant the job u had, was perfectly good and u quit cos they essentially mislead you!
of course u wouldnt stay with those scummers 27k is like maccas wage
oh my bad.. nah i got paid out from nab coz there was not much more work.. i wanted to quit nab anyway and the package was large so i took the bait..
i told the lady if i wanted 27k i would ask for my job at subway back.. f**king dumb dream boats seriously.
Cool, don't forget to change the oil at 1000km and sort out your clutch drag.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
