Nah like after you've pulled the lever to allow passengers in the back to get out, the seat will automatically stop a set position. Is there anyway to change the angle at which it "clicks" in and locks
mine locks back into place at an angle of about 70degrees, its weird.
simple as this really, would you consider a 32 gtr a supercar? no. whats so different about the 35 that makes it so super? essentially the same platform with modern features.
can you stroll into your local Lamborghini dealership and buy an aventador off the showroom floor? no, but you can walk into a nissan dealership and buy a fancy new skyline. and chances are you don't even have a local lambo dealer anyway.
supercar is denoted by the fact that it is a purpose designed model, with supercar performance.
i.e. there are no lower spec models like gtst's etc that dont have the performance.
ergo, 35 is supercar, 32 is not.
I think that last part has more to do with marketing and image.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
