Is it true you can shift without clutching and it does no harm?
This plumber was telling me he never clutches after take off...
Widely debated, but lots of people say that they shift clutchless and never have an issue. I would only do it on the upshift though...
Hmm the Megelli 250R looks even better than the Ninja... None for sale second hand in VIC though...$6k for a new one
The stand hits the ground on left hand leans. YouTube the review clip.. Wouldn't be much fun for a spirited ride and the happens..
like birds says, only upshift.. you have to revmatch to shift down. but it can be done too..
although i have no idea why someone would do that if they had a clutch..
i had no pressure in my clutch pedal for a period of time, had to do the clutchless shifting till i had it fixed.
Pretty sure he's talking about bikes, clutchless shifting is a little bit faster.
I got a sore left hand at the moment, and I sometimes forget to use the clutch cause of the pain and it changes gear.. down gearing is a little clunky haha
What are you riding around TJ? Still hitting the gym?
WTF?!
Hey TJ, where you been man!
what up Jamie!
been working messed up hours bad! living other side of the city now, no more SE for me haha
im on a Kawasaki GPX250 ( old ninja, few pages back ) gym ? hehe not for a long time, gone all soft like now hehe
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
