Booking in for my full license on May 28th, 3 months and 1 day after I did my L's test lol...Hopefully have a crotch rocket before then though
bit early no? must be keen lol
is the fulls test done on public roads or on a course? can't remember
Is his the white r33 with white TCIIs? saw it the other night, did he get epad or something? Had a pea shooter spec exhaust on it lol
Yeah, thats his car - its a varex because it use to have loud as fark twins
Not really, the minimum is 3 months so why wait... Doesn't change anything apart from not having to display an L plate...
It's on a course, doesn't sound much more difficult than the L's test from what my mate has told me, and just means I'll start my 12 months and can legally ride a bigger bike sooner
So you lot - what haven't any of you kicked in??
http://www.skylinesaustralia.com/forums/topic/394651-shitbox-rally-cancer-council-fund-raiser/
I'm just waiting for my PayPal to clear and I'm chucking $100 in.
It's tax deductable as well people - Even if it's only $20, get behind it i say!
I meant bit early booking for a test over 2 months away..
Birds - whats the longest trip you've done on your bike? is a 2 hour trip even possible on a super sport riding position?
I haven't actually booked it yet but there's no reason not to. It's an RDO so I'm not working, and you pay on the day, so no point waiting and risk it being fully booked.
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
