He was a legend of the game and he is an inspiration the way he went about fighting the illness, no disrespect but you obviously don't know much about him to question it.
And yes heaps of people have been through similar nobody is taking anything away from them
Edited by alr33x
If anything, being a celeb he more than likely got special treatment.
So if I die the same way i'll be an inspiration and a legend amongst tradies yeah
What special treatment would he get? He had the same operations anyone else would have.. Having said that you don't have your own charity you probably won't be out there helping others while your fighting for your life either like he was so yes likely less people would care cos you haven't done anything for them
No offence, but how does dying from cancer make you a "legend/inspiration" of the game?
Pretty sure he's not the only one who's battled the illness...
The fact that he kept the HUGE amount of charity work with Reach going all through it?
Raising funds, functions etc. Putting others ahead of himself - means nothing?
Also running the near dead Melb footy club at the same time. Remaining open about everything etc.
The fact he is the only player to play 11 years straight without a game off?
It's not just about that one persons struggle. No-one is saying he is the only person to battle the illness, however the way it was approached and dealt with is not just about cancer, but more so about the world in general. Too many simply roll over and give up
Rimspec is right to some extent. People battle cancer and die from it everyday, and plenty of them will actively help and support others ahead of themselves etc. The fact that he's famous makes everyone feel more sorry for him than Jane doe, it's human nature. Fact is of you didn't know of him you'd care just as much as you did that 20 Jane Does died of cancer before u had breakfast this morning, not at all.
As for him getting 'special treatment', it's true and it isn't. Money talks. He'd get the best of everything available. It didn't save his life, but having fbe best available care/treatment/hospital rooms never hurt anyone.
I'm so sick of the word hero being used for sports stars. I played football every weekend. I'm not heroic. Period. The guys putting their life on the line in Iraq/Afghanistan etc, fighting a war they may not even believe in, they're heroes, they're courageous and inspirational, and pretty much no one will think of them apart from a certain day of the year, or for a quick moment when their death is on the news.
Now let's get back to discussing the real issues. Mine and rimons bike purchases
The media over hype and over estimate so-called sports people...
Hows the bike purchase all going? haha!
This will be my final post on the subject but I really believe he was an extraordinary person. He never put his own life above anyone else's and given the circumstances he always put other people ahead of himself. His work through reach and the way he inspired all those around him is truely remarkable.
I'm not taking anything away from those who are battling cancer, but Stynes' remarkable work is well documented. I'm not even touching on him as an athlete either.
I'm not calling the bloke a hero. Totally agree RE: diggers etc.
Inspirational & someone to aspire too - yes
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
