Counterfeit stuff cheaper in HK or bangkok
add in if you want to leave airport in China there is a visa so there more money to spend.
accom in Dubai and Abu Dhabi can be very expensive for safe good accom, (and you will have all your stuff with you)
that said like all things with airlines you get what you pay for.
and remember you will be stuck in your seat for upwards of 24 hours.
so things like:
every seat in economy on Cathay has it's own power socket
Qantas 380 has a (non alcoholic) bar where you can get drinks and snacks any time on the flight
so is the important thing
cost
stopover
comfort on flight
Martin, thanks for the reply, you raised some valid points.
Have you (or anyone) been in Qatar airlines? Prices are reasonable also the flight time including stop overs.
The power socket on Cathay Pacfic sounds so handy for me... Need to find out the cost for this flight.
No idea, I went on there to post in some thread ,... couldnt do it checked some shit apparently I've been banned from posting ... hahahaha I usually get in there and make threads about drifting lavo factorys n stuff for lulz then they shut down the threads.
Welcome to 2004 - Pretty sure I had a suspension a long time ago :D
kittens are so awesome.
Will hit it often when the mrs' parents holiday house is built there
See how subtle I was there?
SAU brings the LOLS!
not flown them myself.
the Cathay point is great just make sure you carry a UK power adapter as that what they use.
worth checking as well is:
http://www.seatguru.com/
as it shows the size of seats and the space between them for different airlines.
also where power sockets are and seat layout.
eg qatar and Cathay have 32 inches of room between seats Qantas has 31 inch.
hmm starting to sound like a travel agent here!
Martin, many thanks once again!
Qatar - Boeing 777 only have power point in Business Class, however on Airbus A340-600 does have on all seats.
Hmm... Decisions decisions...
Edited by Count Grantleyish
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
