Counterfeit stuff cheaper in HK or bangkok
add in if you want to leave airport in China there is a visa so there more money to spend.
accom in Dubai and Abu Dhabi can be very expensive for safe good accom, (and you will have all your stuff with you)
that said like all things with airlines you get what you pay for.
and remember you will be stuck in your seat for upwards of 24 hours.
so things like:
every seat in economy on Cathay has it's own power socket
Qantas 380 has a (non alcoholic) bar where you can get drinks and snacks any time on the flight
so is the important thing
cost
stopover
comfort on flight
Martin, thanks for the reply, you raised some valid points.
Have you (or anyone) been in Qatar airlines? Prices are reasonable also the flight time including stop overs.
The power socket on Cathay Pacfic sounds so handy for me... Need to find out the cost for this flight.
No idea, I went on there to post in some thread ,... couldnt do it checked some shit apparently I've been banned from posting ... hahahaha I usually get in there and make threads about drifting lavo factorys n stuff for lulz then they shut down the threads.
Welcome to 2004 - Pretty sure I had a suspension a long time ago :D
kittens are so awesome.
Will hit it often when the mrs' parents holiday house is built there
See how subtle I was there?
SAU brings the LOLS!
not flown them myself.
the Cathay point is great just make sure you carry a UK power adapter as that what they use.
worth checking as well is:
http://www.seatguru.com/
as it shows the size of seats and the space between them for different airlines.
also where power sockets are and seat layout.
eg qatar and Cathay have 32 inches of room between seats Qantas has 31 inch.
hmm starting to sound like a travel agent here!
Martin, many thanks once again!
Qatar - Boeing 777 only have power point in Business Class, however on Airbus A340-600 does have on all seats.
Hmm... Decisions decisions...
Edited by Count Grantleyish
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
