Took the VLT to get a roadworthy elsewhere, smaller list and should take a lot less time. I should sell RWC-less from now on, what a head f**k.
The RWC on my Pulsar cost $1,100, only sold the car for $6,000. Bit of a kick in the teeth. Now had they fixed everything it would have been so much more. Never realised how many stupid things count as roadworthy items these days.
Edited by llama_au
not made it out of the terminal at Singapore, want do some day tho.
the nuggets in Germany were that whole fake meat you see on the you tube clips, you know the shite that comes out looking like pink icecream.
and the burger I had somewhere out of vegas on route 66 was just dripping with fat.
Grant yeah quite a few countries sell beer at macca's and co.
Australia is very tight with where you can buy booze.
most other palces are very lax about beer sales, (and stiffer on spirits and wines)
hell thought most of Asia I can buy beer at 7/11
Germany has it for sale from the petrol station
I even found a beer vending maching in South Africa, hows that for responsible serving of alcohol
Ordering a beer with your KFC meal deal combo in Tokyo was awesome :)
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
