Xbox has the same problem, CPU and GPU heatsinks don't stay clamped down enough and vibrations + heat make the components seperate from the motherboard over time. You can also fix an Xbox by putting it in the oven, but it doesn't always work and you can easily damage the other components on the MB. It fixed my mate's Xbox, though afterwards, his Xbox would occasionally freeze with intense graphic gameplay. Ash's mate reckons $85 but not guaranteed to fix...they use a rework station though which is much safer than ye olde oven lol.
lies, ghetto fixes are always the best
just got back from my first proper ride. still alive!
did ~60ks
hit ~130 on the freeway, was freezing! felt like my chest was being punched in...
wrists raped
talked so much shit to myself i ate most the insides of my mouth/cheeks, gets lonely...
at 100km/h bike sits at just under 9k
/bikes
Ride on Sunday may be a go ahead now...bike is getting serviced this morning, hopefully pick up around midday :)
And yeah you spend a lot of time talking to your helmet, mostly about how bad drivers are.
did ~60ks
wrists raped
/bikes
It does take a fair bit of energy out of you, even though u guys are buff kents as well, I'm the smallest with heaviest bike :(
Make a thread? :) <3
Was on melton hwy doing the speed limit this a$shole gets up my arse starts flashing his lights, got out of his way/showed him my finger. 5 seconds later I pull up next to him at the lights, gave him a clap congratulating him on getting so far ahead of me, didnt even have the balls to look my way
On my way home exiting the freeway I stalled the bike taking off uphill at the lights, mint chick stops behind me to make sure I dont get rear ended by someone speeding up the ramp eventhough I waved her to go round, waited there till I got the bike going again.
Moral of the story - there's bad/good drivers just hope I dont come across the bads often
    • I thought it could be an issue because the standard plate was flexing when stressed. Maybe the original gear set will hold a bit better without flex? Last time on the dyno it made around 670nm at the hubs. Now it have bigger turbo and better intake but have not been on a dyno yet. The car is being used from family trips to drag race events. So the shifts can be a little violent. It is grinding if I shift to fast so was thinking I should overhaul it soon.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
