Xbox has the same problem, CPU and GPU heatsinks don't stay clamped down enough and vibrations + heat make the components seperate from the motherboard over time. You can also fix an Xbox by putting it in the oven, but it doesn't always work and you can easily damage the other components on the MB. It fixed my mate's Xbox, though afterwards, his Xbox would occasionally freeze with intense graphic gameplay. Ash's mate reckons $85 but not guaranteed to fix...they use a rework station though which is much safer than ye olde oven lol.
lies, ghetto fixes are always the best
just got back from my first proper ride. still alive!
did ~60ks
hit ~130 on the freeway, was freezing! felt like my chest was being punched in...
wrists raped
talked so much shit to myself i ate most the insides of my mouth/cheeks, gets lonely...
at 100km/h bike sits at just under 9k
/bikes
Ride on Sunday may be a go ahead now...bike is getting serviced this morning, hopefully pick up around midday :)
And yeah you spend a lot of time talking to your helmet, mostly about how bad drivers are.
did ~60ks
wrists raped
/bikes
It does take a fair bit of energy out of you, even though u guys are buff kents as well, I'm the smallest with heaviest bike :(
Make a thread? :) <3
Was on melton hwy doing the speed limit this a$shole gets up my arse starts flashing his lights, got out of his way/showed him my finger. 5 seconds later I pull up next to him at the lights, gave him a clap congratulating him on getting so far ahead of me, didnt even have the balls to look my way
On my way home exiting the freeway I stalled the bike taking off uphill at the lights, mint chick stops behind me to make sure I dont get rear ended by someone speeding up the ramp eventhough I waved her to go round, waited there till I got the bike going again.
Moral of the story - there's bad/good drivers just hope I dont come across the bads often
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
