My 33 GTR was use to driving on the light hehe..
I'd put my 50 bucks in.. get my 200k's lol
Nick! pics of golf!
there is some i put on fb, still waiting for the nuts for the rims to come in from Germany to put them back together
then I'll post up some in ride thread or something
good idea, got a few people that run muddies and they lose usually at least 100kms per tank with those tyres
they look tuff though
what nuts? i've got a set of used bbs nuts somewhere in the shed dont even know how i got em
mine has the light... i see it every time i change from 98 to e85 or vice versa.
with the return line going to a jerry can and a nismo intank pump that pushes 4.6 lt/m the time from when the light comes on to when you can hear the pump start to get loud is like 5 mins
