mirin the drz400sm.. apparently they pop wheelies TOO easy sounds like a good hooligan bike, by that i mean going riding around empty carparks and estates screwing around.. nothing too illegal.. don't worry I wont put SAU stickers on one if i get one.. would be cool being able to go on dirt again :D
your speedo is generally out by 5 kms.
and if they actually detect you at 5kms over, they dont book you because they have to take 2 or 3 kms off that for the fine, and they think its a waste of time to book you for 2kph over.
heard it from a bike cops mouth to pull me over to say my rego is due.
lol for a propper street bike I wouldnt want that, I just take off in 2nd and that gets me to up and over the speed limit easy..
for a DRZ400SM i wouldn't mind changing gears a little more often as it's a completely different bike, would smash any street 250 learner bike to 100 but it's not about that.. it's about having fun and throwing the bike around easily unlike a full street bike
I saw some video of a 250 super moto (WR250X) vs a 250 ninja down the 1/4 mile the ninja got pwned I guess just the gear ratios and weight difference ftw
A lot of cops probably don't care about <10km/h over. I've had a few pull me over for 10-20 over and tell me that if I was doing less than 10 over they wouldn't have bothered.
You can get a fine in the mail, but if he didn't give chase and you don't have personal plates that are easily memorable, it's unlikely you will. Don't start turning into paranoid Mohsen :/
lol paranoid mohsen. lol at him wanting intercooler pipes emailed to him
lol at not taking the money im willing to pay just so he can come and measure...
anyone selling some 3 piece wheels?
more importantly the faces, after 17" low offset centres so i can get some custom barrels and lips made :)
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
