Moh what's the overall look your going for those wheels to me seem better for a euro style ride not a wide body 32
He's a Lebo ofcourse he need big chrome gay wheels lol
It's gotta look tough, and kinda classy. So, functional stance.
Other rim choice is bbs rs' and get custom lips made up.
It's funny how sometimes the passenger can feel the car is sitting on it's limits and the driver can't, it should be the other way round. I had the exact same feeling, was about to tell him to slow down because it was starting to scare me...next corner...skiiiiiid. This is why I like the uphill too, uphill is your friend for stopping quick.
Totally get that, I'm far more confident driving spiritedly up a hill.
