got got back from JDM meet.
mainly as there a wedding car show on at the same time.(found out wedding cars woot)
just take it easy I came out via FTG road and there cops hidden up the street..
Remember the JDM meets well advertised so cops know where they care.
Just had a crazy night at a club on the 31st floor of a building overlooking London. Now I know why all of my British hiphop artists talk about getting home when the sun rises. It's 4am right now in Spring and it's light! Weak! Eye mask, ear plugs: Equip!
lol dudes...its eMsta. Couldnt access my old account, so made a new one. Havent been on SAU much obviously, but just having a read of latest stuff on cars/imports/mods/parts etc. And yeah, am driving in a Getz now - and still not sure what car I will get next - but for now, happy chugging along in the Getz. :)
I still say it's a trap, nobody buys a Getz.
This guy! What up!
Sold the Honda Jazz?
Haha jaime - whats happening man? Nah still got the Jazz - the wife drives it. Got the getz after i sold the skyline cos i wanted a daily.....was looking at hsvs for a while, but heard lots of bad reviews from previous owners, so that plan went down the drain.....am waiting for the veloster turbo to come out to test drive - that should be alright (no skyline, but would be interesting drive)
This guy! What up!
Lol....
Wait wait...nobody buys a Hyundai and Getz away with it...
Why do the perfect lines come later :(
Think I just missed ya. Got there at about 11:30am
Was a bit disappoint at the turnout compared to other meets
Don't mind the look of those Velosters in real life. Got excited when I heard there was going to a turbo model...this was Hyundai's big chance to do something good in a sports car. But FWD, ~$35k, 0-100 in 7.6-7.8...son I am disappoint. Unless that engine has potential the 86 or GTI is sounding like a better option.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
